multiple affiliate alias problem
  • Thread starter Thread starter vinci16
vinci16
Hello, everyone.
I found a problem with solidworks 2017.
In practice I have to bend over a sheet, the problem arises when these folds are perpendicular.
solidworks in this case does not make the second desired bending.
is someone able to provide a solution?
I leave attached a copy of the piece and a drawing of the finished piece in order to understand which bending must be carried out.View attachment Montante 850 con 2 pieghe (2) - Copia.rarmontante.webp
Good morning.
I don't open the file with my version, but I can only view it.
I think you have to scan until the end of the ray.
modify the discharges until the end of the ray and then do the folds.
I hope I've been clear... .
Good morning.
Forgive me, but I can't figure out what you mean by "scantonare".
I can't set the value 0 because there is a minimum value to put.
Andrea
increases the rectangular cut, which you see in the figure, until you reach beyond the radiation of the fold you have already done.
make a cut similar to the green square... .
If I have time I give you an example... .
as I imagined the problem was solved by taking advantage of your advice.
I moved of that much that just bend the direction of the axis of the mount so as not to collide with the edge where the perpendicular bending must be carried out and the problem disappears.
Thanks for the help.
Andrea
