multiple bubbles
  • Thread starter Thread starter BerAnd
BerAnd
Hello, everyone.
I can’t (because it’s probably not possible :frown:) to create multiple attacks in the bubbles, I’m better attached: a unique bubble for 5 components with the bubble line pointing to all 5 pieces.
Does anyone have a solution?
The only one I found is by means of symbols (asterisk, more, etc...) that recall the bubble... but then I ended the symbols and they forbid me to use letters and numbers.
I'd love a version of proes doing this. I have the wf3 m220.
Thank you all for your help.
if you select the bubble, 3 key, change attack,
a menu appears, where you have the possibility of
add references.
when the bubble has more references,
you must select in the "biforcation" because
reappear the reference menu
Hello sweptblend
the attack change command for the bubbles allows only the movements of the attack itself and not to add attacks, that command is in light gray unfortunately.
Hello sweptblend
the ball to which Berand refers is the automatic one, managed by a repeat region.
the function you are looking for is a lack of pro-e (that I know both in the wf3 and wf4, in the wf5 I don't know).
I "resolve" the problem by showing all the balls that interest me and then I align them to handle so that it is only one with more directors.
I'll get you an image of my system.
we hope in the future.... .
great alex70, a "porcata" :biggrin: worthy of a great user proe!
Immediately!
Thank you so much!
of nothing, it is a pleasure to share the "porcate" due to the motto: "improvise, adapt, achieve purpose."
hello and thanks to the "big user" of pro-e....
