jim78b
ciao chiedo a voi che siete esperti, io ho questo lisp che mette l'oggetto selezionato (blocco) su by block. tranne che vorrei quando chiede di selezionare l'elemento di selezione tramite finestra più elementi e non solo 1.
; file name: fixblock.lsp
; description: puts all of a blocks sub-entities on layer 0 with color and
; linetype set to byblock. the block, itself, will remain on
; its' original layer.
; revision:
; 3-dec-2003 yz
; changed program to work from a keyword on the command line
(defun d_fixblock (/ eblocksel ; block selection
linsertdata ; entity data
sblockname ; block name
lblockdata ; entity data
esubentity ; sub-entity name
lsubdata ; sub-entity data
icount ; counter
;; redefine error handler
(setq
d_#error *error*
*error* d_fb_error
) ;_ end setq
;; set up environment
(setq #sysvars (#savesysvars (list "cmdecho")))
(setvar "cmdecho" 0)
(command "._undo" "_group")
;; get block from user and make sure it's an insert type
(if (setq eblocksel (entsel "\nselect block to change :"))
(progn
(if (setq linsertdata (entget (car eblocksel)))
(if (= (cdr (assoc 0 linsertdata)) "insert")
(setq sblockname (cdr (assoc 2 linsertdata)))
(progn
(alert "entity selected is not a block!")
(exit)
) ;_ end progn
) ;_ end if
(progn
(alert "invalid block selection!")
(exit)
) ;_ end progn
) ;_ end if
;; get block info from the block table
(setq
lblockdata (tblsearch "block" sblockname)
esubentity (cdr (assoc -2 lblockdata))
) ;_ end setq
;; make sure block is not an xref
(if (not (assoc 1 lblockdata))
(progn
(princ "\nprocessing block: ")
(princ sblockname)
(princ "\nupdating blocks sub-entities. . .")
;; parse through all of the blocks sub-entities
(while esubentity
(princ " .")
(setq lsubdata (entget esubentity))
;; update layer property
(if (assoc 8 lsubdata)
(progn
(setq lsubdata
(subst
(cons 8 "0")
(assoc 8 lsubdata)
lsubdata
) ;_ end subst
) ;_ end setq
(entmod lsubdata)
) ;_ end progn
) ;_ end if
;; update the linetype property
(if (assoc 6 lsubdata)
(progn
(setq lsubdata
(subst
(cons 6 "byblock")
(assoc 6 lsubdata)
lsubdata
) ;_ end subst
) ;_ end setq
(entmod lsubdata)
) ;_ end progn
(entmod (append lsubdata (list (cons 6 "byblock"))))
) ;_ end if
;; update the color property
(if (assoc 62 lsubdata)
(progn
(setq lsubdata
(subst
(cons 62 0)
(assoc 62 lsubdata)
lsubdata
) ;_ end subst
) ;_ end setq
(entmod lsubdata)
) ;_ end progn
(entmod (append lsubdata (list (cons 62 0))))
) ;_ end if
(setq esubentity (entnext esubentity))
; get next sub entity
) ; end while
;; update attributes
(idc_fb_updattribs)
) ; end progn
(alert "xref selected. not updated!")
) ; end if
) ; end progn
(alert "nothing selected.")
) ; end if
;;; pop error stack and reset environment
(idc_restoresysvars)
(princ "\ndone!")
(setq *error* d_#error)
(princ)
) ; end defun
; function to update block attributes
(defun idc_fb_updattribs ()
;; update any attribute definitions
(setq icount 0)
(princ "\nupdating attributes. . .")
(if (setq ssinserts (ssget "x"
(list (cons 0 "insert")
(cons 66 1)
(cons 2 sblockname)
) ;_ end list
) ;_ end ssget
) ;_ end setq
(repeat (sslength ssinserts)
(setq eblockname (ssname ssinserts icount))
(if (setq esubentity (entnext eblockname))
(setq
esubtype (cdr (assoc 0 lsubdata))
) ;_ end setq
) ;_ end if
(while (or (= esubtype "attrib") (= esubtype "seqend"))
(progn
(setq lsubdata
(subst
(cons 8 "0")
(assoc 8 lsubdata)
lsubdata
) ;_ end subst
) ;_ end setq
(entmod lsubdata)
) ;_ end progn
) ;_ end if
(progn
(setq lsubdata
(subst
(cons 6 "byblock")
(assoc 6 lsubdata)
lsubdata
) ;_ end subst
) ;_ end setq
(entmod lsubdata)
) ;_ end progn
) ;_ end if
(progn
(setq lsubdata
(subst
(cons 62 0)
(assoc 62 lsubdata)
lsubdata
) ;_ end subst
) ;_ end setq
(entmod lsubdata)
) ;_ end progn
) ;_ end if
(if (setq esubentity (entnext esubentity))
(setq
) ;_ end setq
(setq esubtype nil)
) ;_ end if
) ; end while
(setq icount (1+ icount))
) ; end repeat
) ; end if
(command "regen")
) ; end defun
; function to save a list of system variables
(defun #savesysvars (lvarlist / ssystemvar)
(mapcar
'(lambda (ssystemvar)
(setq lsystemvars
(append lsystemvars
(list (list ssystemvar (getvar ssystemvar)))
) ;_ end append
) ;_ end setq
) ;_ end lambda
lvarlist
) ;_ end mapcar
lsystemvars
) ;_ end defun
; function to restore a list of system variables
(defun idc_restoresysvars ()
(mapcar
(setvar (car ssystemvar) (cadr ssystemvar))
) ;_ end lambda
#sysvars
) ;_ end mapcar
) ;_ end defun
; error handler
(defun d_fb_error (msg)
(princ "\nerror occurred in the fix block routine...")
(princ "\nerror: ")
(princ msg)
(if *error*
(*error* msg)
) ;_ end if
(command)
(if (/= msg "quit / exit abort")
(progn
(command "._undo" "_end")
(command "._u")
) ;_ end progn
) ;_ end if
(princ)
) ;_ end defun
(defun c:fixblock () (d_fixblock))
(princ)
; revision:
; 3-dec-2003 yz
icount ; counter
(setq
d_#error *error*
*error* d_fb_error
) ;_ end setq
(progn
(progn
(exit)
) ;_ end progn
) ;_ end if
(progn
(exit)
) ;_ end progn
) ;_ end if
(setq
) ;_ end setq
(progn
(princ sblockname)
(while esubentity
(princ " .")
(progn
(setq lsubdata
(subst
(cons 8 "0")
(assoc 8 lsubdata)
lsubdata
) ;_ end subst
) ;_ end setq
(entmod lsubdata)
) ;_ end progn
) ;_ end if
(progn
(setq lsubdata
(subst
(cons 6 "byblock")
(assoc 6 lsubdata)
lsubdata
) ;_ end subst
) ;_ end setq
(entmod lsubdata)
) ;_ end progn
) ;_ end if
(progn
(setq lsubdata
(subst
(cons 62 0)
(assoc 62 lsubdata)
lsubdata
) ;_ end subst
) ;_ end setq
(entmod lsubdata)
) ;_ end progn
) ;_ end if
) ; end while
(idc_fb_updattribs)
) ; end progn
) ; end if
) ; end progn
) ; end if
(princ "\ndone!")
(princ)
) ; end defun
(setq icount 0)
(cons 66 1)
(cons 2 sblockname)
) ;_ end list
) ;_ end ssget
) ;_ end setq
(setq
) ;_ end setq
) ;_ end if
(progn
(setq lsubdata
(subst
(cons 8 "0")
(assoc 8 lsubdata)
lsubdata
) ;_ end subst
) ;_ end setq
(entmod lsubdata)
) ;_ end progn
) ;_ end if
(progn
(setq lsubdata
(subst
(cons 6 "byblock")
(assoc 6 lsubdata)
lsubdata
) ;_ end subst
) ;_ end setq
(entmod lsubdata)
) ;_ end progn
) ;_ end if
(progn
(setq lsubdata
(subst
(cons 62 0)
(assoc 62 lsubdata)
lsubdata
) ;_ end subst
) ;_ end setq
(entmod lsubdata)
) ;_ end progn
) ;_ end if
(setq
) ;_ end setq
(setq esubtype nil)
) ;_ end if
) ; end while
) ; end repeat
) ; end if
(command "regen")
) ; end defun
(mapcar
(setq lsystemvars
(append lsystemvars
) ;_ end append
) ;_ end setq
) ;_ end lambda
lvarlist
) ;_ end mapcar
lsystemvars
) ;_ end defun
(mapcar
) ;_ end lambda
#sysvars
) ;_ end mapcar
) ;_ end defun
; error handler
(princ "\nerror: ")
(princ msg)
(if *error*
(*error* msg)
) ;_ end if
(command)
(progn
(command "._u")
) ;_ end progn
) ;_ end if
(princ)
) ;_ end defun
(princ)
