names parameters inventor
  • Thread starter Thread starter windreef
windreef
Good morning.
There is a list with the names of the various parameters of inventor, for example sheet rule would be =<sheet metal="" rule=""> .
to me in particular would serve the distinct structure name components (normal, purchased ect...) to be able to create a voice in the custom iproperties and do so directly from the distinct components together.
but also having a total list for any future needs would not be bad.
I searched, but, I'm wrong, the search terms or autodesk does not release this information, once autocad was available the list of variable names.
Thank you.</sheet>
Good morning.
in the separate components of the axieme there is already the column of the distinct structure components of each file, and changing the voice of that cell directly changes the written attribute on the single file.
so to what pro to create a custom iproperty?
I think I didn't understand the need.
said this, I do not know if you can tie the attribute of the distinct structure components of a file to a property of the same (I don't think) but, via ilogic or with an external development, you can recover the distinct structure components of a file in a certain distinct (as it appears in the current axieme).
this because the attribute "bomstructure" is contained in the object "componentoccurrence", and not in the document object, so the information is recoverable for a certain set in which the file is contained.
Good morning.
you are perfectly right, there is already the possibility to display it in separate. Sorry.
Is it Friday?
Good morning.
I use vaults have folders where I have already split my cads as "commercial parts". can you change the attribute of a part by setting it as purchased? otherwise I should every time check all the separate to verify that there are no commercial parts set as "normal" instead of "acquired". I hope I explained.
until I use a part in a set and then I check the separate how do I know if that part of my part is by default set as "acquired"?
hi, I don't know if I understood the question well, however the commercial parts in the content center are already set on purchased, the ones you insert new you , you have to set them as purchased before entering them in the content center. If you have an external library in the content center, the same thing, consider that every new part created with inventor is, by default, set to normal
you have an external library in the center contained with the commercial parts that I unload online or that I create. but when I create a part, how do I set it up as "acquired" without having to change the state when I put it in a set? I usually open the distinct components of the assembly and then change the status of a part from there.
in separate components together - only parts
choose the column "different structure components" and see all states of the various parts.
with all cells of the distinct components you can interact as with excel for which you can make copy-paste where and as you want provided that the component is not read-only or cc library
How did he tell you
Remember that if external libraries are set in read-only, it is normally practice to do so but it depends on who created it, it will not make you change the files inside, I to make it imposed the project by default in which my libraries are not set, I change the file , in this way I can save it, then I close and impose the work project
