nanocad - print in grayscale
  • Thread starter Thread starter il disegnatore
il disegnatore
Hello.
use nanocad 5.0, that is the latest release.
the problem that matches the press without the possibility to enter the "scale of gray/greyscale".
leaving print settings on none, obviously print as from layer (and if there are colors you see correctly)
if instead imposed on monochrome.ctb uses only black.
for reasons of reading drawings, I would need to print in grayscale.
all the cad archive, on other posts using other cads, automatically recognize the tone to print.
where a procedure can be available to create a new ctb with the requirements of the grayscale?I hope to have been clear.
if nanocad uses .ctb file extension, I suppose you work the same way as autocad.
it is about creating a ctb (magari starting from the color one), in which you go to change one to one the 256 predefined colors, in the corresponding grays (going to vary the chrominance and maintaining the luminance)... until you get the desired grays: what in the monochrome.ctb file is placed all in black.
It's a long job, but once it's done, it's forever. I can't help you anymore, not knowing nanocad.
Clearly, I knew that. in previous autocad stations we had set it up and each time you copied the file.ctb created in the software usage folder and correctly you could print with the gray scale.
I tried to insert the same file...unfortunately it doesn't seem to work.
Has anyone already made a print style with gray scale? Is it possible to export them?
Hi, I managed to copy the desired ctb files, in hidden folders of explore program resources.
Now it works properly, if you should interest someone this is the path.
c:\users\vostronome user\appdata\roaming\nanosoft\nanocad int 5.0\plotstyles
