navigate between open drawing windows in autocad for mac
  • Thread starter Thread starter giuseppe85
giuseppe85
Hello everyone, I wanted to know if there is a way to quickly navigate between a window and the other in autocad per mac.
setting some keyboard commands or alternatively installing some apps! thanks in advance
:cool:g
it is best to directly use system functions such as mission control and the like.
open "System Preferences", select mission control, select on the bottom left: "active angles..."
associates "windows application" to one of the four corners. I think the most comfortable is the one on the lower right.
Alternatively, you may also associate "mission control" instead of "windows".
However once you do this you can switch from window to window at speed of light.
to remember that by default mission control is associated with f9 and gesture with 4 fingers up and windows application to f10 and gesture with 4 fingers down. However, I think the setting with one of the corners is much more immediate while using autocad.
If you want you could also press command and point together to open the dwg window and autocad layouts directly.
