nc machine simulation
  • Thread starter Thread starter Filogorla
Filogorla
Hello.
I am new to the forum, in caia v5 p3 r16 in the nc machine simulation section, after creating machine and processing, starting the simulation via tool path, it works but without the removal of the material from the rough.I would not want to miss in the creation of the piece I go to work because it created a cadpart with two body one the rough and the other the finished piece is just as a process? :smile::smile::smile:
removal does not occur when you turn the simulation of the tool path..... to see the removal of the material in the screen that appears when simulating the tool path you need to click on the camera or camera icon. . .
but by starting the simulation using camera or camera controls you can only see the piece and the staff, you can't see the whole machine. To me what would be needed is simulating seeing both the removal of the material from the crude and the machine in operation. because on youtube I saw videos that during the simulation via tool path you also saw the removal of the material. a way to see both machine at work and material removal is possible??? Thank you.
You can... But only if you're out of money...
I'll explain. .
The simulation of the machine doesn't need anything but it's just something that's good to see... slowing down the system, weighing it down and providing no additional information... .
However if you want to do it you should buy the postprocessor directly from catia.. .
if you go to tools options machining tab emissini see that in the first row is indicated the post porcessor to use (my is set on anyone as I want the output file with aptsource extension to be neutral)....
to have the simulation of the machine should appear there the postprocessor of the machine you use for simulation. ...
it is possible to simulate the removal of material if you use a machine used by catia as an example and one of the postprocessors in the above list. . .
I did it but I repeat it is a tool machine used by catia as an example (if spulci in the folders where caia is installed there is a folder where there are some examples of processing but there are also some machine tools)
ok I have created the machine with mechanisms and everything to get simulation via tool path with material removal as should I set the menu in options -->machining-->emission ??? what postprocessor should I set and what path pp??? the menu I mean is that in the photo
Maybe I didn't explain well.... .
You can't do it with your car. .
you can only do it by using a tool machine already prepared by catia.. .
search them in the installation folders. . .
the machine with which you find it in programs dassault b21 win64 startup manufacturing samples ncmachinestoollib device the machine is the mill_5axis
choose the car you have to make another couple of steps but I do not remember them now
so with the machines that I created can't??? sin. but then if I created a machine with mechanisms with ball recycle screws, he created the mechanism in machine tool build then I go to kinematic and created rack joint (prismatic+rotation) then in the simulation of the machine does not work...for the mechanisms I have to use only those in nc tool build?? ?
So... .
If you want me to see the removal of the trucile then you have to use the machine that you find in the cat itself unless, as I told you, you do not purchase directly from dassault the postprocessor for your car... .
if you want to move the machine by following your tool path just create it with tool build paying attention to joints
But buying postprocessor for my car does not know about excessive spending? so I can also use kinematic joints just put them in the mechanism of the machine;) ok thanks a thousand hairy;) excuse the trouble and thanks anchoraaaa;)
Hi, I just registered because I'm interested in simulation.
I also with the machine tool builder I made a 6 axle machine (actually it is a 5 axle mill + a rotary axis that coincides with the spindle). the machine for if it works but I can't figure out how to move the machine using a iso file type
x10 y-5 z45 a8 b-30 c34
Can anyone help me?
daily use catia for cam molds.
thanks, greetings
Excuse me if I interfere. but from this module is it possible to simulate the whole machine?
