mauri98
Good morning to all,
I create this discussion because after several hours and attempts I am not coming to the head.
I should make a laying to accommodate the piece (3d in attachment). the only solution that came out was to use the "cavity" function. I had to create a set, insert the laying and the piece, then use the cavity command. as a solution I'm sure it's wrong, but I tried anything without succeeding. how would you do that?
p.s. use solidworks 2009.
