Hello everyone! I ask your help because I can't insert two ribs into the part I created. Would you be so kind to help me? I attach photos of the piece and thank you in advance.
Can't you do it because it gives you some mistakes or other reasons? However you have to draw a 2d sketch equal to the red lines of the image placed above, and then, with the nervation command, select that sketch. be careful to choose the right option depending on the sketch plan (parallel or perpendicular).
