network file opener with autocad 2006
  • Thread starter Thread starter buzzo
buzzo
Hi, I installed autocad 2006 on windows 10 in a domain.
it works all, except if I go to the network and click on the dwg file, it opens autocad and tells me impossible to open the file: or it does not exist has been moved.
Does anyone know how to solve this?
these are the minimum requirements for autocad 2006
  • processor intel repentum iii or later versions of 800 mhz
  • microsoft windows xp (professional, home edition o tablet pc edition), windows 2000
  • 512 mb di ram (mentioned)
  • 500 mb of free disk space
  • vga screen 1024 x 768 with 16.8 million colors (minimum)
  • mouse or other pointing device
  • unità cd-rom
  • microsoft internet explorer 6 sp1
read somewhere 'windows 10'? probably this is not only the problem but if you mount old software on recent operating systems and do not work properly, it is useless that you come looking for help on the forums
  • unità cd-rom
read somewhere 'windows 10'? probably this is not only the problem but if you mount old software on recent operating systems and do not work properly, it is useless that you come looking for help on the forums png to ico
thanks to the answer
well... the requirements of 2010 are xp-view-win7, which despite the fact that i can safely turn under the latest version of w10 (10h2).
then as it is specifically stated are minimum requirements not maximum.
you run in compatibility mode and the program starts and works quietly.
i don't think that's the problem.
and if you open it more "manual" (of the type from autocad open files and look for in the path)?
