new presentations in writing. request info
  • Thread starter Thread starter Fabcad
Fabcad
Hello, I'm new to this community! I would first of all like to greet all the members of the group and to thank in advance those who will participate in my discussions and respond to my requests. I, as far as I know, will try to be useful and to contribute with my knowledge.
I'm new to catia and I'm not very familiar with the program. so I would like to ask for an info... I hope to explain myself well. Suppose I create any feature in the environment (after creating others) and we still suppose that for some reason I realized that this feature should be moved over... then I make button on the feature and then relocate (or something like that). the probema is that when I move this feature on the following ones are no longer displayed at video!!!! It seems that there are no... and it is not a question of hiding/visual... because they are all active!!! What's wrong? I hope I have clearly expressed my doubt. Thank you in advance!
Welcome.
What you do is correct. When you move the feature, the tree stops at the feature moved. the feature in question you see underlined.
you have to put yourself in condition to make the last feature active and this is possible in 2 ways between them almost identical:
1st way---right button on the solid tree owner then go to click on "definite in work object"
2nd way-- right button on the last command of the tree then on "define in the object of work".
we waved
Thanks mocca!!! clear and precise...! I did not realize that the program "stops" to the feature moved!!!! gracias!!!
No, no, you still fly low.. very low.. I interrupted the cad to make some portraits on commission... and I have two more to do.. I think they pull more than 3d drawing, but less and less than a fur of.. :biggrin: and as if not enough they are father for the second time :wink:
