new style dotted line
TECNOMODEL
I would like to create a new style for a dotted line by changing the length of the dash and the spaces between the strokes.
I can't find where these parameters are set. in the management styles I find only the thickness line, type and color.
Is it the heat that "trips" me or cannot be done?
the line type should be indicated when selecting a layer. you can also select another and choose from the available line types that are saved in a .lin file. in my case is acadiso.lin. just open it with notepad and add or change the line that interests and save the file. (I usually when I do these tests save the original file you never know).
it tells you when you select other line and at the top it tells you file name and path (however it is the same that you use in mechanical)
