next development to the senate vote
  • Thread starter Thread starter gfrank
gfrank
private building receives a strong impulse and the designer responsible for approval has more charges
approved on 21 June at the chamber, the development will be shortly to the senate vote. as regards private building, the decree brings with it changes aimed at reducing bureaucracy for the permits to build.
the first measure is that of silence-absence, which subsidizes silence-refute, with which you will be able to determine with certainty the times to obtain the building permits (enablement title). The only manager of the instructor will be the private designer, who sees increasing his burdens, including that of integrating the documentation for the release of the permit with his statement, in which you certify the conformity of the project to the building regulations, anti-symics, security, sanitation and energy. in the decree the recruitment is expected from one to three years for false declarations or certifications and the indication to the professional order of competence for disciplinary sanctions.
the trail (starting certification) will be extended. In practice, both the prerogatives and the procedures of the municipal offices will change. the person responsible for the procedure has 30 days, starting from the submission of the application, to stop the examination and request supplementary documents. Moreover, they may pass up to 40 days before the measure becomes definitive, if the same manager has communicated to the applicant the reasons that hinder the approval of the project.
Silence-absence is valid in all cases except in one or if there are environmental, cultural or landscape constraints.
source: http://www.geometra.info/dl-svilupp...tm_campaign=newsletter_geometra_26_05_07_2011
