nightmare editing designs other cad print pdf only color
  • Thread starter Thread starter Emc2
Emc2
the compatibility of mechanichal 2013sp1 with other platforms seems to have worsened much compared to the previous releases, I was trying to process files exported to .dwg from me10 (I don't know the origin version) . to change the design that I had to completely explode all the elements losing also all the grips of the quotas and trying to find a type of quota compatible graphically with the existing also the text editor to insert really bad notes and direction working. printing or export in pdf also inserting the monocomatic style produces pdf in color in both cases this forced me to change the color of numerous yellow texts resulting unreadable with the white background of pdf. I also tried the option set drawing by importing a corporate model used by us.
roberto
no I have drawing filles created by me10 exported in dwg format and processed by mechanical 2013 sp1.
I tried both to print pdf with a visual printer and with the export command setting the monochrome style and clarification having activated the flag "uses the styles of tampa" but the tables come out in colors in both cases.
roberto
I imagine that exporting from me10 lines colors have been attributed with rgb or hsl color patterns and not index colors. if printed with color print styles (.ctb) and lines do not have index color, it comes by force all colored. try to control
no colors are table ctb I also tried to replace them in the various layers but the print preview design and also in the print remains colored.
roberto
It's a me10 settling problem, it's not enough to declare printing in bn you also have to set the set of pens for monochromatic printing, proof, by memory I don't remember the path but in the preferences of pens should be there one that assigns all colors to different pen thicknesses.
Let me know.
