no associated publisher
  • Thread starter Thread starter pasticcio75
pasticcio75
hello to everyone, they are new and use catia 5 for several years (they are not very practical of installations, updated etc.)
problem: My client sent me the 2d and 3d files of a project. when I try to open the catdrawing tells me "impossible to open the file.. no associated editor. . . "
typical problem when dealing with files saved with a newer version.
example: you have v5 r18 but are trying to open saved files with v5 r20
I thought so, but they were generated with my own v5 r19 version.
and anyway the associated catpart I open it quietly. . .
If you send me everything I try to open in cv5 r20 so we know more
I also have the same problem: I have a 2d and a 3d made with the same version (r19). the 3d I open it without problems but I can't open the catdrawing: (laughs) impossible to open the file. no associated editor)
have you managed to figure out what might be the problem?
thank you 1000...
hi, the problem seems to depend only on an error of "file transfer" or "file compression"
in plain words from how it was "sweet" or sent (if it passes through some server or ftp area)...
in my case it was a transfer problem. . .
Siete per caso riusciti a capire quale potrebbe essere il problema?
Ciao, il problema sembra che dipenda solo da un errore di "trasferimento file" o "compressione file"
in parole povere da come è stato "zippato" o inviato (se passa tramite qualche server o area ftp)...
nel mio caso era un problema di trasferimento...
saluti
Hello, thank you for your feedback!
I guess then I have the same problem because the files are saved on a server.
Sorry the question a little stupid, to solve the problem as you did, asked who created the files to raise them or re-invite them?
some of our customers use companies that provide security data transfers (crypted). These companies had misplaced some parameters. . .
