no longer takes the intersection snap
jim78b
in a drawing when a line or a block crosses a bow or circle, it no longer finds the snap intersection ... become mad. I try to redesign apart a circle with a line that crosses it sees it, then I think the explosion block I collect nothing to do.
the entities that "intersect" are placed at different quotas.
Otherwise attach a part of this file where you have the problem, which we do first.
Maybe you unintentionally disabled the "snap".
post an image of the screen so we understand:
1: what you have
2: if snaps are active
3: on what kind of lines you are working on.
Planner caught us.
for verification, as osnap from the appint keyboard (apparent intersection) and you will see that it finds it.
use the _flatten command of the xpress tools or the following "macro" created on a special button
_all; ;
Of course! lines and blocks etc are all at altitude 0 . the apparent snap int takes it but is imprecise. excuse to attach the graphfetta asks http....how do I say the directory?
Don't trust me. sometimes, with _dddunits set to 3 digits after the comma, you see the quota z=0 but in reality it is z=0.00000562 that is different from zero!
try to launch _flatten or the macro I wrote you above
In fact, if you explore the block and see the properties of the arch, you will find that the z is...
the _flatten works, but you have to get into the blocks to get him to do his job!
If jim has billions of blocks and wants to finish the design before retirement, it still solves with the suggestions received "sopra", that is with the arranged combination of osnapz=1 and osnap=intersection apparent. :mixed:
Sorry guys but the problem does it to me with another new file!! why not? in the dwg file I'm drawing a tunnel silk I put the arrow where it doesn't take the intersection! Hell a new design!
By force, the green polyline is placed at an elevation of -0.00000025.
