no shortcut keys are activated
  • Thread starter Thread starter romi
romi
as from title I have a problem with the shortcut keys, in fact, if I click ctrl+ any number the command does not work. if instead I click ctrl+lettre or various f1 etc. No problem. I tried to see if I had unintentionally activated the block of numbers but I see that it is all in normality. I ask you what can be the determining causes of the problem and how to solve it, thank you.
Have you tried to see in the custom interface if they are actually present?
Yes, I looked in the interface and how you can see from here it seems not to see them. How do I activate them?
but really from what you see at least designcenter is present (ctrl+2)... :confused:
if it is for this in the user interface you see all the "ctrl + numbers" but, I don't know why when I go to click them from keyboard do not activate the command.:frown:
stupid question... does the control work? did you try to do it with the other right or left control? I'm telling you why a colleague of mine happened the same thing with the shift and the keyboard's key was no longer working!
he said that ctrl + lettere works properly, then the button is in place.
probably is more a .pgp file configuration problem
si, il tasto ctrl It's fine. I repeat, the problem arises only if you want to use ctrl + numeri, using ctrl + letters all works well. I also tried on other programs to use ctrl + numbers and everything works. I only have this problem on autocad.:frown:
Um...
is it not that the command works, but the window appears "out of the screen"?
to me it happened to find me in a little corner.
I recovered it just for a couple of pixels
...if I do for example ctrl + 2, in the history of the operations carried out there is nothing, then I exclude the hypothesis that the window could appear outside the screen and find it in a corner where you do not have the possibility to see it. the strange thing is that in the user interface it shows me, so in theory it should activate them, and instead...:confused:
...if I give the hand command for example by typing _adcenter I have no problem... let's say that the alternative is...I wanted to understand why I did not activate the command with the shortcut keys (ctrl + numeri).
tried to recharge the configuration to which?? ?
...this is a good answer for those who have never been involved in such a matter. I would ask you at this point not to complicate things a step by step procedure.
