node traliccio
  • Thread starter Thread starter danilo47
danilo47
I attached pictures to clarify the problem.
in the environment structures it is possible to realize reticular structures by assigning various profiles to the elements of the lattice.
The problem is that the profiles are not tagged in the exact way, from the image you can see that the profiles enter the other section.
how to solve this problem, also because at the time of the design of the element, as it is done to give the exact cut of the extremtita of the element.
there is no attached image
in the "structure options" are the "angle treatment options" that do what you need (if I have not understood bad).
search in the guide because everything is explained well.
Bye.
