nome del frame
  • Thread starter Thread starter micgiul
micgiul
Hello everyone.. .
I am delighted to plan in lisp and I have a question to which for the moment I have not been able to find answer. . .
Automatic loading my carts with this command line.
(docu-register-frame :ui-name "a0" :wm-name ") :file "<unita>:<percorso>)
All right.
now I would like a function that returns me the name of the currently loaded frame.
i.e. for the above line I would like to return the :ui-name "a0".
I tried with sd-am-frame-p functions etc... and all those like that but I don't get back the string I want.. .
thanks as always for the collaboration.
Michael</percorso></unita>
but to fill out the paper?
Hello everyone.. .
All right.
I can fill out the cartilage automatically with the indications that you already gave me in your time. . .
now I want to add also the possibility to put revision by adding lines to the cartiglio itself according to the revision number. . .
only that the size of my cartilages vary if they are a3, a2 etc...
So I wanted to know if there was a function that comes back to me the name of the cartouche.
for now I do with the sd-am-sheet-struct-corners function that returns the coordinates of the two points of the cartiglio and quinidi I can understand what size it has.
thanks for the collaboration.
Michael
You could get it from the name of the cart. if you edit it from osd_drafting (me10) you can associate to the top part the name of the cartiglio. You should be able to get your name back.
I tried how you told me and I finally managed to make macros in me10 drafting.. .
the macro me10 neat here and there and definitely to optimize is the following:
(sd-execute-annotator-command :cmd (format nil; frame name
"define am_inq_name_of_frame"
"parameter target_pid"
"local name"
"local output"
"inq_part target_pid"
"let name (inq 301)"
"let output (format_message '{1}'" (str name)"
"the output (docu_cstring_to_lstring output)"
(docu_open_connection_to_sd)
"(docu_add_line_to_sd output)"
(docu_close_connection_to_sd)
"end_define"
and to call it back I used this code:
(setq sheet (sd-am-inq-curr-sheet))
(setf list_object (sd-am-inq-sheet) sheet)
(setf dim_frame (sd-execute-annotator-function :fnc (format nil "am_inq_name_of_frame \'~a\'" (sd-am-sheet-struct-frame list_object))))
This is the name I gave in me10 to the frame.
Michael
