non-associative measure?
  • Thread starter Thread starter if2111
if2111
Hello everyone
a little problem.
I press that I wanted to insert an attachment but here from the office you cannot
I hope that I can give the example in an understandable way.
in sketcer build three parallel straights.
between the first and second straight insert a dimension (constraint)
between the second and third straight insert a measure (measure between).
Now, at the varying size should also vary the size,
but unfortunately it is not so it seems that the measure is not associative.
I think it's weird. Maybe I miss a set.
What? ? ? ?
Thank you all and wish with the good Christmas occasion
try not to use the measure and put a reference fee and the thing works ................... .
unless you want to use the "distance between" by force............ .
otherwise go with the dx button on the measure and the next with local update, after exiting the sketcer .......:wink:
or go to options - parameters and measurements - measuring instruments and selections automatic update for part or axiemi or both and automatically update when you leave sketcer ...................................... .
I forgot good Christmas to you and the whole forum
thank you for the help!!!!
I expected the update of the measure to happen inside
I was lost.
This step.
