non-functional canc key
  • Thread starter Thread starter aledani
aledani
Hello everyone, I ask you a help...I'm going crazy because I configured autocad2011 after using for years autocad2007. .I can't understand why the canc command doesn't work as a keyboard ... maybe it's a setting in the options panel.. but I can't understand which...someone has the goodness to give me advice.? thanks in advance to those who will read my post
Does it work in windows? that I know there is no way to reconfigure a button in autocad, but I might be wrong.
options -> selection board -> check name/verb selection
thanks guys, for the solution, just set the variable pickfirst = 1 from command line and I solved the problem.
I hope sooner or later I can return the favor.
good work at all
Thank you very much. banal but effective, I had reset the ceckbox.
I should have gotten there myself.
