selli29
Good morning, everyone.
I have noticed that the odds that contain the diameter symbol are not printed correctly in pdf: the character is displayed in the drawing area and in the print preview but once printed in pdf is not recognized (I see a set of balls instead of all the text, not only of the diameter character). the font I used is very normal arial, which I normally use for all odds, and the quota was created using the diameter quota tool. the same problem also occurs by applying a local change to the text of a linear quota, and inserting the symbol ø (diameter) through the combination %%c. I tried on different computers and actually the problem also occurs on all others. in fact with some fonts instead the problem does not occur but, I wonder, there is no way to insert differently the symbol so that I can continue to use the font arial?
I hope I've been not too confused in the exposure of the problem!
a thank you in advance to those who will kindly help me!
