northern project rotation crash
  • Thread starter Thread starter piotta
piotta
It's been a long time since I've been working on the current project and I realized that the so unplanned designs are bad, so I decide to rotate the north of the project using the fourth option available in the dialog box (align the selected line or plan).
I run the operation on a file of about 110 mb and, both setting the orientation on the real north and project*, the program crashes and fails to perform the operation.:mad:
I also tried to rotate the north of the project using the rotation command of the real north and using the input that appears under the ribbon under the heading " angle between north of project and north real" and setting the rotation of the real north to 0° but the operation fails.
Can someone tell me a solution?? Thank you!
* (which instead creates problems in the rotation phase of the real north giving error and asking to change the orientation from n. real to n. project)
the version is the 2014 suite (the one with instrument and mep included) and I installed the 2 updates available, did I not understand if you mean the service packs of windows? I also installed the service pack 1 (I think it's the only one and the last one).:frown:
