nx 1847 series
  • Thread starter Thread starter ceschi1959
siemens & halke è stata fondata da werner von. siemens e johann georg. neck il 12 ottobre 1847
+Hello, excuse me for the ultrasynthetic question, and thank you for the aneduct.
I wonder if this is a release for nx12 or more, in gtac, I see it and having nx12, I wonder if this is an upgrade version or other software connected to versions of particular licenses
Good day
davide
the first world fair is held in the Hyde Park of London from May until October 1851
Did you see if there's a what's new?
interesting part file compatibility, on the other hand already in the 11 if you opened a file made, with a mp10 (make an example), with a mp04 appeared to you a message that more or less said:" this command was done with a more recent revision and could not give the same results".
hello thanks to the possible answer
Hello,
to use nx1847 and/or nx1851 is an updated license request? (I now have nx12 )
Moreover, they must be considered as an update release with each other in the sense that, being now nx1851, it is worth downloading this and jumping nx1847 .
nx from this year will release continuous releases, it seems that there will be no 13, for this year it seems that the nx 1872 will arrive in honor of carl friedrich von siemens (birth year)https://community.plm.automation.si...ajor-release-of-nx-will-not-be-13/ba-p/445584https://community.plm.automation.si...cement-nx-continuous-release/bc-p/499513#m654
it seems that there will not be 1872 because going 4 years in 4 years, who knows why:
1847 gen
1851
1855 March
1859 Apr
1863 exit now, there will be:1867 and 1871
then 1863 in may and 1872 in june
can you anticipate in january that number is coming out?
1863 is the current version.
beginning of june the monthly update (1867)
then on 21 june the 1872 series.
from them forward every month an update comes out, until 13/12 in which the new "major" comes out (if so we can define it). the number will be 1899.
after this forward of 4 in 4 each month
in semiannual cadence will come out the other "major" (1926, 1953).
unfortunately i no longer have time to install versions in advance, so i see the news when they come out.
