nx 7.5
  • Thread starter Thread starter Max-C
Max-C
but how do you insert the sample when you do a section view?
thank you and excuse the question that may be trivial but the company is beginning to invest on this software and I can't send to the table suppliers with paradoxical errors:-)
But the problem is more complex than I thought.
In summary I have a .igs that is just a set of functions. How do I turn it into a solid?
Bye. I don't know if I understand your problem. but once imported igs join the faces. then see what remains of open (analysis geometry) and close the remaining areas.
you could try to give you a more consistent format to transformation into solids, such as the jt or the step... to start.
from iges may not be trivial to have a solid.
to all and thanks for the interest,
I couldn't have stepped because the designs are from another company.
I solved by changing import parameters.
in practice before he saw the component only as a group of functions.
after he saw it as a solid and then the sampling was present.
hello to all:)
