alulecia
Good evening to all,
I've been a nx user for about two years and recently I've been to version nx9.
I would need support from more experienced users on two issues trying to be as clear as possible:
1) how to manage the cloning of complex axioms:
my typical work solution is as follows:
I work by splitting the files of model 3d and 2d therefore for each component (assieme) I have to manage two files.
typical situation is: together1 + table with 2 (content together 1) with relative table
I have no problem at the time of cloning axieme 2 and its table, but I would like to know whether there is the possibility or another strategy which allows me to clone axieme 2 with its table (and therefore also together 1), bringing me also the table of axieme 1 which is clearly not directly read by the axieme1
I hope I've been clear.
2) Has anyone of you noticed that nx9 does not allow to replace in the reading folders of a file together with the same name?
in previous versions often happened to me that by necessity I was forced or needed to modify a single component and after doing so, I simply replaced the file in the folder; having kept the same name the tree of assembly was updated quietly and I had no problems
Now with nx9 this game fails me and although the new file has the same name I am not read by the assieme.
someone knows whether it is a editable setting or if the new version tracks in some other way the origins of the files.
Thank you very much
Thank you very much
