nx 9 - check wall thickness
  • Thread starter Thread starter jasper
jasper
Good morning.
I need to do a thickness analysis with nx9:
- is check wall thickness correct?
- what are the correct settings to have an analysis of the right thickness?
Good morning.
I don't understand what you mean; If you look at the settings, you can set a tolerance and the calculation method, it is logical that within these parameters the result is correct. the result is qualitative and directs you to areas where you can do further analysis. I used it to estimate where there are risucchio areas with excellent results.
