objects placed on different floors to change the view
  • Thread starter Thread starter marsigiu
marsigiu
Hi. are the first weapons in building a 3d building... I have a problem.. when I change the view many elements change place and it turns out everything!:confused: how to do? ?
Alllego photo to be clearer.... help! !
marsigiu, do not post in different places.
do not send private messages like this: do you know about cad 3d? ... and then do the same demandate in other discussion that does not center anything with your question.
I'm not using autocad.
other thing, it is good to present to other users, as indicated by the regulation.
so wait for you to get an answer from some users using your own cad.
as he wrote maxopus, first you must:
- indicate the cad 3d you use (and then post in the dedicated forum)
- the type of error related to the context of the "instrument" used for the design.
in your case the coating moves, but what did you use to draw it: an object? a retino?
I used the parallelepiped instrument in autocad 2010. .
most likely some objects are on a floor other than that of the main facade.
try to use the orbit to choose an angle other than the isometric one. you will notice in a moment of error
I didn't understand where the xke error was the elements were in different plans and I didn't know how to do it.. I've done everything... now I have another problem... I finished all 3d .. now I would like to apply materials... I go to apply them but I can't see them in the realistic view. Why?
you should know exactly all the steps you've done to apply the materials.
materials may also be disabled in realistic view
