objects
  • Thread starter Thread starter braunfish
braunfish
the design assistant tells me that some iams and ipts of the project have attacked objects that will not be the subject of any changes I will make.
Moreover, these same files that have these wings attached, give me problems in the table setting (inventor crash). Is it possible to detach these blessed oles, that I don't even know what they are?
should be things like an imported .jpg with copy and paste (maybe the logo in the carts? decals? ).
from the always efficient f1:
you can stop links to documents with ole link in patterns and drawings from the embedded elements dialog box and document links. in that dialog box are also listed all embedded objects in the file.
in the All-In-One bar click on the tool tab group options links.
in the embedded elements and document links dialog box, select the document with the link to be interrupted. you can select only one document at a time.
After highlighting the document name in the dialog box, click the Stop Link button. is required to confirm the operation.
click done to close the dialog box.
Thank you, too. I've been trying to figure out why the assist puts us so much to open up....tolto the damn link ole....guadagnato 30 sec in opening.
If you had problems in the mixed raster-vector printing and/or with the oles (excell files etc.) we have third party printing drivers that solve the problem: recommended by hp, autodesk and in use by several of your colleagues.
www.paolocasella.it> > > > > > > > > > > > > plotterdriver - > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
> > > the cad and prints
