oblique dissecting holes
leggera
Hello.
I would have the need to dissect circular holes, but forced at an angle of 15° on the plane, so in the plant they are ellipses,
when I go to dissect the piece the section function does not suggest me with the dotted line fake the projection of the various characteristic points.
Do you have any idea?
because I'm starting to use inventor.
Do I need to update the profile?
It is not mandatory, but at least you avoid asking useless questions like mine.
As far as your problem is concerned, I don't understand it, it explains better.
I would have the need to dissect circular holes, but forced at an angle of 15° compared to the plan, so in the plant are ellipses
All right.
at the table?
the section function do not suggest me with the dotted line fakes the projection of the various characteristic points.
I don't really understand this, what suggestion does this fantomatic " section function " give you?
You're right. I wasn't very clear.
when I go to dissect a tilted hole does not suggest at least one section line.
I attached table and part.
I may mistake some passage, but with the hole perpendicular the section I can do it quietly, while if I want to do it on the oblique hole I can't.
when I am in front of these situations I usually do a random section line. Then I issue the sketch of the section line, I project the geometries I need and quoted or constraint regarding those my section line. I'm going out of the sketch and I'm fine.
I did not know that the section could be managed as a sketch by binding it.
it is good to always bind it, so you have the maximum control in case of changes of the model.
It is also important to find the right references for constraints.
if you proceed with logic and order, the puts on the table are more easily manageable and recoverable with similar details.
