appioclaudio Guest Jul 1, 2010 #1 good morning to all, would you know how to insert and visualize in drawing the offset lines(the guidelines that indicate the trajectory of the exploded components) inserted in the exploded? Thank you.
maxopus Guest Jul 1, 2010 #2 you need to insert them into the assembly, when you realize the explosive there is the command in the view management panel, look at the image. Attachments Immagine.webp 44.7 KB · Views: 29
