Stefano0308
Good morning.
I'm working on an oil bath clutch.
the tree that you see in the image, has a room below which is filled with oil not under pressure.
the radial seal, circled with red, is a hn2390 ptfe seal with the metal body.
the problem and that friction must be able to work in all positions, but when placed below it exudes oil after a few hours. the clutch will have to work up to 5000 rpm with an alternate cycle, " 3 seconds in braking, 3 seconds at rest. "
I chose this estate because at low friction as the clutch will be used as a control tool for other equipment and will be examined the pair curves.
I also tried the estate hms5 v , but unfortunately in the test phase adds too much torque due to the highest friction of the same.
do you have ideas/solutions on what kind of seal could I use to solve the problem?
Thank you for any answer you can give me.
Have a good day.
Have a good day.
