ointments in 3d pdf 2012
  • Thread starter Thread starter FIGOR71
FIGOR71
Good morning, everyone. .
I noticed if I try to save a set or part in sw 2011 in pdf extension, I find between the options "Save as 3d pdf".
on small parts or assembly(10/20 parts)nn there are problems and I create a pdf 3d, while on large assemblies(300/500 parts) sw 2011 nn wants to know. . .
Can you tell me where I'm wrong or if there's a remedy?
Good job
to work it works, because I did it on a new project where we passed the thousand unique pieces.
you can:
1) update the service pack if there was a possibility
2) Restore installation using windows command under installation-applications
3) reset solidwoks logs
4 uninstall and reinstall with deactivated antivirus
you can:
by chance is it possible, once generated the pdf 3d, move the parts as well as I do within solidworks? or is it only possible to set an animation?
Andrea
with pdf 3d you can only orbit in the axieme. .
good morning ivan,
thanks for the clarification. since you know this type of export well, i take advantage of it again. in pdf 3d i like to use the orbit with a fixed axle but it is the z axis that does not correspond to the vertical one. how can i change the axieme in sw to get this?
thanks again
Good morning ivan,
thanks for the clarification. Since you know this type of export well, I take advantage of it again. in pdf 3d I like to use the orbit with a fixed axle but it is the z axis that does not correspond to the vertical one. How can I change the axieme in sw to get this?
Thanks again
in solidworks depends on the positioning of the parts according to the origin, if you position together or the parts so you have z axis as a vertical axis, in pdf 3d after export should keep turned together. to orient yourself in the lower left corner in the solidworks window you can see x;y;z axes. so it's all in how you start placing parts in the set. There is a way to change it even in existing assemblies (without going to touch the constraints of the assieme) at the moment I don't remember well, should be a command in the views, as soon as I have time to do so to be able to explain it in a decent way.
