paolomath
Good evening,
I hope I don't ask for things already seen... I created a block (layer 0) inside which I have a circle placed on the layer holes.
I insert the block into a drawing and put it on the layer buttons.
if I step from on to off the state of the layer buttons continue to see the circle, if I freeze the layer "disappear" everything.
here or.k.
If I switch to paper space, within a viewport, I can only freeze/disclose the layer buttons in the view.
can I set the viewport in order to repeat the same situation as the model space?
I thought so. Is there an exit?
p.s. autocad 2015.
Thank you, Paolo.
here or.k.
p.s. autocad 2015.
Thank you, Paolo.
