only resolution problems?
  • Thread starter Thread starter barby85
barby85
hello to all, as from title I have a problem when mold, in the sense that curved lines are snap printer, that is like a succession of straight lines....I attach you the pdf done where you see the problem....the figure is a cylinder with a spiral that envelops it.
when zumo in the 3d file the curved lines are all straight, but I know that it is a problem of my screen....but why this also happens in pdf?
to explain better: do you see the red lines of the image? should be continuous curves not broken...I thought it was a problem of resolution monitor....but when I carry the part in 2d I get out so the contours...I tried to make regenerates but nothing....in autocad the lines remain so and also in pdf as I attached you. . I hope you can help me.
the video resolution you can set it in view> display settings.
other thing is printing in pdf, which is independent from viewing quality.
When you launch "Save as pdf", the window opens where you choose the print quality.
However it is strange, because the default quality is 300 dpi and should not give you those problems.
How do you launch the press?
how do I launch the press?
cmq is a problem that gives me even when the transport in autocad....mi displays the contours as the red lines of the image, so much so that I have to stand there and combine evventual lines that do not join, double lines, but above all the lines that should be a continuous curve are a thick line, even after regenerates?
you can print in pdf either with the pdf save command, or by launching the normal print command and choosing your virtual pdf printer.
the best results I get them with the first.
on which I use that command...in fact the pdf that you find in the annex I did it with that command and with a resolution 300....how does this happen to me? is it a problem of how I insert the measures? in the sense that I make my designs in 1=1mm
also because-running me if I'm wrong-in the monitor I can see also the segmented line(resolution issue) but then the line is an equation so it should print right....also in pdf...
certain quality to video does not affect the quality of printing .... Can you post the file, so I do some evidence?
I thought you posted the drawing.
from the side file only I see nothing.
if you can also post the *dtl file for drawing settings and config.pro.
this is printing in pdf using your drw and my configuration files.
Everything looks fine.
now I verify without my configuration files and with your dtl
Maybe I know what this is about:
you have to go to visibility'>visualization model>spigolo line>qualita' spigolo> high
try to do this and tell me what results you have
Thank you very much!!!
changing the value from medium to very high the problem is solved.
But now every time I reopen quality is always on average: Therefore I wanted to ask you what is the parameter in the conf file to be fixed (I tried to look for it but I couldn't find it) and if there is an equal parameter in the conf file of the design.
I also attach 2 files: one is the drw and the other is its dwg. as you can see in the drw (in the circle) there are lines that I don't understand, that should not be there (the curve line that then stops).... these lines are also reported in the dwg and always in the latter many lines do not join (if zummi much see that many are not united)....in fact I couldn't create the outline as the only polyline and this because they were not joined? I hope to have been clear:tongue:
