open dft "advanced"
  • Thread starter Thread starter ipotemusa
ipotemusa
I would like to propose a change to the macro open dft.
I try to explain:
now only works if the dft has the same name as the par/psm/asm.
if however from any dft you double click on a view opens the associated file.
My proposal is:
make a macro "linka dft", to start from inside the dft that opens the par/psm/asm in the drawing, adds a text variable with the path of the dft and saves.
must therefore be implemented in the "open dft" that you do not only look for the same name, but that you look in the variable of the par/psm/asm opened the link to the table.
Did I explain?
I don't think it's a problem.
silvio
I try to explain:
My proposal is:
Did I explain?
silvio
interesting proposal, when I have some time I implement the thing.
