open file in a light way
  • Thread starter Thread starter sernic
sernic
Hello I was sent you a "product" very weight that I do not want to open.
is there any way to open only the structure so as not to weigh the ram? or there are other ways
go to tool/options
"infrastructure" tab - "product structure"
tab "pruduct visualization" deselects "do not activate defaul shapes on open".
Let the cat go again.
at this point opening an axiema only loads you the product structure.
to load individual parts you can select a part and right click "representation" - "activate knots".
max max
Thanks again but I still had a question.
if at this point of a set I want to activate only a subaxieme composed of other subaxieme there is a fast way to do it without having to go backwards along all the know tree?
Sorry, sernic. but I'm not sure I understand the question well.
if you want to activate the subaxis with all its lower levels, use "activate terminal node".
even if you did not understand well you answered right!!!! :biggrin:
:smile:
