open multiple designs in one work session
  • Thread starter Thread starter IN.TEC
IN.TEC
I have a problem with autocad lt
every time I explore resources I double-click to open a drawing instead of displaying it in the autocad I opened, the system opens me another session and opens it to me and so every time I need to open a drawing.
What is the variable to change?
thanks and good week to all.
Faithful
variable variable variable variable taskbar (barraapplications in Italian) to set to 0.
from the online guide:
command voice: taskbar
type new value for taskbar <0>:
type 1 to view multiple open drawings as separate items on the Windows application bar
the default setting, 0, displays only the current design name on the Windows application bar.
if it was spoken here too:
http://www.cad3d.it/forum1/showthread.php?t=5867
as it had already happened to me for another problem that I had the changes you had indicated do not work on my autocad lt
I swear I don't know why.
It's two more days I'm going crazy with history. .
...but do you think it's a set of view or autocad? ? ?
It's very likely that it's a setup to give in the operating system, as indicated in the second link I reported to you.
I don't know sight, but there must be something like that.
back to the problem because now it is more urgent to find a solution
It's practically learned that it's a vision problem and not a uatocad, but does anyone know where I can go to set something up? ? ?
Faithful
p.s. for the moderator
if no more interest in autocad discussion can you move it somewhere where there may be any expert?? ? Thank you.
