open object from other pc
  • Thread starter Thread starter Stefano80lt
Stefano80lt
Good day to all,
I'd need to know, how to open the same pr Object from another pc, which has the same version of inventor, but that doesn't find me the bolt and everything about the bookcases... .
the whole itch has been transferred via usb key, and all folders have the same identical path.
(inventor 2017)
thanks to the answer,
I didn't actually... I took the prototype file. I salted it as it is.
I used the inventor's library, and as a result, I would like to open the same items in the other pc
You may change the project file by indicating a folder in the centre of the workspace. so you find all the files generated for that model and you can copy everything together. obviously the first time you have to copy the files of the c.c. that you have in the default folder (the ones copied from the pack&go, so there are only those related to that specific model)
