open to mouse passage bar hidden groups in autocad 2010
  • Thread starter Thread starter warburg
warburg
Before starting the climb of the mountain revit I thought to make a small heating using autocad with the interface 2010 :-) and I ask a tiny thing: the All-In-One Bar is divided into tabs and each tab in groups. I understood how they manipulate, how they insert or remove icons etc. etc., now I would like if the hidden part of each group, to open which you have to click on the dart, you opened directly alone to the mouse passage, tide ladra, so that you have to make a single click to call a command... They seem festive, but when you're ten hours to click. . :-)
It's not possible. At least I don't get this chance in autocad.
maybe with some utility in .net...
Thank you, I was hoping for revit...
I have a vague idea what it is:-)
at the moment, for the .net (c# above all) is still soon to find utility... apart from those released by autodesk programmers (kean walmsley in particular).
Okay.
"How come they didn't think about it?" the phrase that always comes to mind who does not make the software programmer:-)
However, I noticed that this multifunction bar is very "delicate": Sometimes when you click on the titles below to expand it... disappear the corresponding group! go look for it in the group list, and it appears, but you just don't see it anymore. Then I can make it reappear after a series of random steps, turn on again do and do again.... Mah.
a remedy there is.... use fast keyboard commands... customize the pgp file and with a button (maximum 2) call the command without moving the mouse !!!
who uses autocad from before the general icons is faster in this way than with icons....
Bye!
the 3d mouse would also like me...maybe sooner or later I take it. But now I'd love more than the All-In-One bar came back visible, it disappeared last week I don't know xke' and I can't get her back, you know if there's any command?
Thank you so much!
That's right.
