openable roof with wheels
  • Thread starter Thread starter Emc2
Emc2
I would like to make a roof in carpentry with smooth insulated panels the dimensions are 5000x2500 the sliding side and the narrow one
I wanted to know if to realize the slide I could use combined wheels on profiles to c in order to use the channel also as a roof hooking site to the underlying stucco , without risking blocks for crossing the structure that would be enlivened through a rack and a pinion connected to a gear motor from gates . or better use a v guide on one side and on the other a flat wheel by requiring the connection with the same structure.
the type of wheel composed that you want to use is this but I wanted to know if you find other similar products having no experience in this field. http://www.winkel.de/it/all-winkel-bearings/?tx_winkelproducts_pi1[bearing]=1122&tx_winkelproducts_pi1[action]=show&tx_winkelproducts_pi1[controller]=bearing&tx_winkelproducts_pi1[bearingGroup]=23&chash=d573edccd06ec7643a4d55351a7c8444
If you have no experience and put a 5x2.5 mt gate in your head, be careful when you step below.
Happy birthday, not just for Easter.
I would say:
- you must be an architect or engineer qualified to the profession and with adequate experience
- you need to properly size the roof according to current regulations and have permissions from the municipality
- a rack protruding equal to the short side of the roof????? ? I would say that the movement must be realized with other mechanism
- a c guide or a v and under a plate? make a drawing because you don't understand anything. any guide must be 100% stable even with snow and wind in all circumstances
- calculate bendings, efforts, deformations, ntc 2008 and eurocode 3 for structure, bolting and welding of elements. other industry standards.
If I were you, if you have all the skills and requirements I would do it, otherwise I would be more with my feet on the ground and I would build a wrought iron flower with the curls.
