opening tables without views
  • Thread starter Thread starter loredi
loredi
Sorry, but I have a bigger problem tonight.
at the opening of some tables, no more views appear. preview you see clearly, then making some attempts sometimes come back to open. I also tried on copies made days before and the same thing happens on different computers. I'm desperate for help.
Did you rename the files of the parts that were represented in the tables?
you can check if there are any suggestions with the linkages between the solidworksexplorer files.. .
it is true I have verified inside of solidworks explorer and it is just so but no longer asks me to locate the file because?
You probably answered a question that you didn't ask. try to control in system->options->advanced.
options\advanced
in discarded messages select the one reported to the message of "file not found". in doubt, select them all. Okay, you're gonna get the messages you said you didn't show up anymore, including the files you didn't find. Don't tell the program not to let it appear again.
Great, I reactivated from options-advanced all the messages that I had disabled and now asks me again to manually locate the files that you did not find. I fixed everything. I'm safe. Thank you very much to all.
