PSP11
Hello.
modeling ruins of a castle I need to drill the existing masonry detected and shaped with the wall command and defined with profile modification to insert a variable section opening in width.
I can shape a local mass, but I can't get her to accept the program because she says:
"This mass does not have solid geometries from which to cut gaps. must be eliminated or it is necessary to add solid geometries to be cut. "
the opening is a classic rectangle with a rounded side, with a width of 1.5m inside and 0.7m external, with fixed wire along one of the sides of the window.
I hope you can help me.
Paolo Pagano
version: revit 2012 - version for students
Paolo Pagano
