19sbirro87
Hey, guys.
I have to optimize the weight of a bridge with rectangular beams (link8 type elements) loaded with 1000 tons (equably distributed on each node) respecting the constraints on the maximum shift of each node[umax<10cm]and the maximum stress. I must also respect a constraint on the section of each beam: the sections must be between 1cm^2 and 400cm^2.
I built the bridge considering the starting structure constituted by elements with an initial section equal to 400cm^2, obtaining a weight of the structure equal to 968[tonnellate].
Now I have to check what happens if I change the starting section of the beams, so instead of 400cm^2, I have to consider 1.5,20,50,100,200,400[cm^2] and see what happens.
I tried to perform the analysis individually by creating a different project for each section and the weights of the structure vary according to the starting section, the lower the starting section, the more the weight decreases..... according to you the right thing?? ?
Shouldn't the results converge to the same weight?? ? ?
responses, thanks
responses, thanks
