drake
Hello, guys.
I don't really use the rescue of bodies on a mutibody side, so I don't remember if there is an option that allows you to automatically update saved bodies when changing the parent multicoprpo part. I'll explain. .
I have a multibody part to which I save the bodies. I then reopen the multicoprpo and make a change to a body, but I realize that the modification is propagated only if I open the modified body simultaneously. That could cause mistakes. I remember in the past that when I opened a multibody from which I had saved the bodies, sw opened at the same time all the referenced parts, so it was sure that the modification propagated correctly. Now when I open the multibody father doesn't open all the child parts to me anymore and then an incorrect update problem could arise. I tried to search between the options and the guide to set the opening of all referencing files, but I didn't find the option. You know what to set?
