orientation noted with director
  • Thread starter Thread starter Mr. Hauza
Mr. Hauza
Good-bye, you stupid enough question, but I've been taking me in for a while now. from the latest releases of inventor I can no longer direct the text of the notes with director (in the table) as in the old versions. until the east to the right or left is fine, but when I put it up or down the text aligns vertically (and not horizontally) forcing me to turn my head to read the content. first in any verse I put notes the text was always written horizontally (justly). that you know there is a way to rotate the text within the notes? Or do I have to keep them like this? Thank you all.
I honestly don't understand the problem.
if I touch notes with director and you keep clicked on the grip point under the text (I don't know the precise name) and try to rotate everything works.
hello, peppe, thank you for the answer. I don't remember if there was this problem in 2019. The problem I'm getting is that if you put the director vertically even the text aligns vertically despite you always need to see it horizontally. I don't know if I explained. before even with the vertical director the text was readable horizontally.
in previous versions the director even if you put it vertically the text remained horizontal. now not anymore.16986726407685358730561275178890.webp
However it seems normal to me that the notes are orientated in that way if vertical.
If you want the text stacked it doesn't seem possible
No, unfortunately not. It is bad to see, impossible to read but above all until the 2018 version (memory wash) worked as I told you. So for us in the office in the version passage we were pretty bad... let's say that. 😅
on 2020 just take the last point of the note with director and drag. . both vertical and horizontal.
Just not to look like a visionary, this is the first table at home I found. beat error aside, you see the director point down while the text remains horizontal. Now if I reopen this table with 2023 if you try to move the note and the text aligns along the director and I no longer have the chance to put it like this.16986813668463558767802647483617.webp
I know, but the text changes orientation with the director. I wish it was always horizontal as in the image I attached in the previous answer. I don't know how to turn it.
Just not to look like a visionary, this is the first table at home I found. beat error aside, you see the director point down while the text remains horizontal. Now if I reopen this table with 2023 if you try to move the note and the text aligns along the director and I no longer have the chance to put it like this.View attachment 69510
I have done several tests but a behavior of the note with director as it requires or you have done in the past I have failed to replicate it.
I ask you: the contents of the note you post is written by hand or is a parameter of the part called for example description?
No, it's indifferent. either handwritten as a text or as a parameter the text always follows the director. Unfortunately, when you have little space, it would be convenient to put the director up while keeping the text horizontal. I'm beginning to believe it's no longer possible but not to give me an explanation.
I go to memory because I don't use inv anymore for a while but it seems to me that it's a twist of the drawing std, you have to force putting the text always horizontal and not aligned. I don't remember if you have to create a different text style.
I have to try and cuff some. I don't remember ever seeing settings about it but I'll take a look and let you know. Thank you.
If you see my image some response ago, the old versions of inventor when you took the grip and vertically pulled the text kept reading horizontally. Put a note of 4-5 lines where you have to explain something and read it vertically is ugly sincerely.
what settings do you have? to me all puts them horizontally without problems1698753829575.webp
Hi, I have the same ones as you. the problem arises when you try to put the director vertically while the text has to remain horizontal. I can't do that anymore. He used to do it automatically.
Sorry, I lost the concept of director. pardon
"I have done several tests but a behavior of the note with director as it requires or you have done in the past failed to replicate it. " I never had the problem. But it would have been cool. now she wants to have it to me ora
