orientation plans with view
  • Thread starter Thread starter mokir
mokir
I don't know how to reverse the direction of a plan axles:
I would like to create a higher plan that has the axes oriented in this way: the axis facing me, that x which points to the right and the y that goes up.
in a few words I should rotate the x axis of 90 ° without that you roar even the rectangular plane.
but there is no soul that knows how to rotate the coordinate system wcs?
I found only the reverse command and does not rotate.
Hey, Mokir, I'm sorry, but I can't figure out what you want to do. in the first post you say you want to create a plan while in the second you have to rotate the origin. Can you explain what you have to do?
I do not think it is possible to move the origin of the existing axes, as it is not possible to move the 3 basic plans.
If you have to create another origin you can do it as you want.
Thanks for the answer and I apologize for the terminology; the answer you have already given me: I just wanted to change the global coordinate system of the upper floor (so called in autocad ) by 90° , but I realized that it is not possible and thinking about it is logical that it is so.
Mokir
Mokir
the coordinates of a single plan can not change them/roll them (at that point you create directly a plan rotated as you want), but you can change/seat the global ucs on a point or vertex. and direct the axes x, y, z along a edge, a sketch line, towards a point etc. etc.
so:UCS.webpI have never used it and so far I have never found the need (it is also that I am not very experienced..); what would it do to you?
Mar
I actually wanted to do something that doesn't need anything.
It was the first impact with the program interface that made me deviate.
the 3 floors default orietabili for the views and the possibility to rotate the ucs, they cover all possible imaginable needs .
Thank you for the time you dedicated me.
Mokir.
so:View attachment 9524I have never used it and so far I have never found the need (it is also that I am not very experienced..); what would it do to you?
Mar
However the origin of the (initial) axes remains and cannot be moved, create another where you need it.
