Legs
I tried and tried it again and I just can't track the line using the tracking (it must also set it with relative rotation).It is sufficient, in the settings, to set 90 as a right angle and polar measurements compared to the last segment.
f10 to activate the polar pointing.
instead I also thought about the possibility that it is banally that to rotate the original segment (clearly if it is not a block or other).
just select it, select a grip, press twice the space write and send p send (or b if the English version) and select the intersection and rotate 90°. then cut the surplus parts.
That is what seems to be a question, but it is actually a very fast operation.
possibly the same operation can be done with mocoro. Select the segment, use mocoro to copy and rotate around the starting point.
if you may interest I return a link to the conversation found on the autodesk site that reports, basically what we told more a specific lisp to solve the problem.
