overall construction and saving .bdl
  • Thread starter Thread starter AquilaDelLario
AquilaDelLario
after 6 years that I no longer use osd, a company gave me an osd ver.15 station to start a collaboration.
I press that they too are not able to use it.
I was asked to put in 3d and relative tav.2d some their old designs and I wondered if it is possible to "build" the total 3d and from the parts/groups attach the annotation tables so that when I go to change a piece in total I will be able to update also the tav.2d without loading the single .bdl
thanks and excuse for the niubbaggine:biggrin:
save your 3d set as .pkg and every single table in .mi
the .bdl includes both 3d and 2d
saving in .bdl to recreate the axieme you have to upload every single .bdl file ...
much better to save in .pkg and .mi if you do not have a pdm.
in the company have a pdm but obviously on the car they gave me does not work
maybe for what the .bdl files want?
then confirm that first I have to do the individual .bdl then assemble them?
However today I will make some evidence
Thanks for everything
no, the pkg contains all the 3d you see at video, so all the hierarchy of components.
I'd do this to you.
models all 3d in pkg format, when you are finished go to your customer and save it on pdm creating codes and graphics. only after you make the boards, possibly sitting in your client's house so the association between model and table is automatic inside the pdm. This is because otherwise to tell the pdm which table is associated with which model becomes a bit brigorous.
What do pdms use? I'm working for a client from my office, and I'm connected to their pdm over the internet. the situation is indistinguishable from working internally, without prejudice to the complaints due to file transfer, but in the case of the external flow--> company are not very important because they move a few kb at a time. different if you need to load a 3d assembly from the company server, in that case tens of minutyi may be necessary or even hours.
alternatively try to explore the 3d-data format, alternative to pkg.
made a single pkg and many tables saved as drawing.mi
Alternatively you can save the boards in bdl but in this way you will have the double 3d, that is saved both in the bdl file and in the total pkg and updating one ndevi remember to update the other manually as well.
if you
If you don't have the pdm save them so, otherwise save them in pdm, but don't listen to the solidedge moderator, he wants to send you to paranoia to discredit osd!!!!:tongue:.
the association will always remain if you work correctly or you have to solve the total 3d after generating tables.
