overlap correct lines on public pdf
  • Thread starter Thread starter MORENO100
MORENO100
Hello.
when I publish a pdf, known that the overlap of the lines is not correct, for example the green lines dotted of the hidden profiles erroneously overlap the black lines of the unhidden profiles.
Is there a way to solve the problem?
thanks and good work
p.s. use wf5 and creo2
I know that the problem would be solved by using the "superposition quality" available in prints, but I want to know if it is possible to do so also by publishing a pdf because using this last method by obtaining a pdf with a much higher definition.
I correct what I said, for "overlay quality" I refer to the "interface_quality" option, but it has nothing to do with the solution of the main problem.
therefore remains the fact that by printing a pdf you get a management of the overlap of the correct lines otherwise posting it no. you also have the same drawback in publishing a pdf? If you don't, can you help me?
Thanks again.
